Dicehunter
Resident Newb
Just got some black cable combs from E22, A few 24pin and 8 pin ones, This style but black
Ooh some cable training on the cards.
I hope you know how to use combs properly. Yes you can do it wrong but I have trust in you.
I'm really excited, I know it is stupid to be an early adopter but I couldn't control myself.
Dont you have cablemods cables?
Just ordered this
Fractal Design Kelvin S36
Now i just have to work out what after market fans i'm going to put on it not sticking with the fans that come with it, Thinking about either the EK Vardar or Fractal Design Venturi.....Tough choice.
I can attest that the Kelvins are brilliant coolers, nothing really wrong with the stock fans TBH and the Venturi fans are about on par just that they are black not white. The biggest thing for me with the Kelvin is the ability to expand and refill it. I have considered going with clear tubing at some point.
I'm not saying the stock fans are bad there just not going to match into the idea for the build i'm working not that's why i'm planning changing to all black cause i'm doing a Black/Red build but more black than red.
I'd probably get the FD fans. The Vardar's are great performers, but QC seems to be lacking. Reports of high pitch noises when running low RPMs are becoming more common it seems. I'd even say get some proper Noctua fans or even some GTs. I have 3 GTs. All of them at 12v are more quiet than my previous Corsair SP Quiet Edition fans at 7v, while pushing more air just for a reference to compare too. I have the stock fans with the Define S, 140mm fans, while bigger and run slower they have about the same airflow but are still very quiet. So based off my FD fan experience, i'd wager they are more than enough for your needs and probably cheaper too considering you will need multiple
The F3 Vardars I have are "whisper" quiet in my rig I actually hear my D5 over them and that is only on 2
