Doomslayer
I have a 500R and the PSU surround was slightly warped from the factory, I dented the side panel moving it around and the rubber gromets make my hands go black (they also killed a set of bitfenix extensions before I worked out what was causing the discolouration.)
Aside from that however I'd have to say it was very easy to build in and looks good (imo). Was also one of the first (mid tower) cases I came across that supported 240mm AIOs out of the box.
But yeah starting to think of new cases for my next build. Won't be for a while as the Z77 and the 3770 is still very capable. I'd like a smaller form factor tho. MATX or something. Tempted by the H440 and the NIMNI 805 (once you see it it can't be unseen) but nothing has made me feel I absolutely have to pull the trigger just yet. InWin was very close to getting my dollars..
Now if the Define S came in white...![]()
That was a common problem was case that were made back then, I had a NZXT Phantom 410 in White back in 2012/2013 and even on mine the rubber grommets went the same way, I think it was really bad rubber grommets back in those days.
