AverageNinja
Average Penis Too
Doubt anyone here likes them but I got me some boots
I like them too man!
everyones having Beyers now and I'm sitting here with sennheiser ones...![]()
because they are fucking awesome
guess what lol I have the opportunity to get some T1 from beyer rather cheap
-snip-
The T1 telsa?! That's $1400 :drool:
You will need something a lot more powerful than an e10k though to drive those cans... 600ohm is far to much for an e10k
I will try them with the e10 first, especially since the other dac I ordered needs longer than the T1s
A new hobby.
Something small to start off with: FTX Vantage 4WD Brushed.
I went in to ModelSport UK and it was so busy that I forgot that I wanted to get the brushless version. I'm wondering if I can upgrade this version to a brushless motor. I don't suppose anyone here knows what would be required (besides the motor)?
Need an ESC and a brushless motor, then the conversion kit, mounting and stuff, are you using a LiPO battery setup already?
why not just return it and get the version you wanted? might be cheaper
I'm just using it as stock. Comes with NiMH battery.
I see I'd need the brushless ESC and motor and LiPO battery. What's the conversion kit?
Just that, mounting hardware for the motor and ESC, also to go with LiPO's you need the charger.
What it might be worth doing ringing modelsport and tell them you wanted a brushless version and if they could make you a kit to bolt in, then sell the old stuff on bay of e
Yeah that's a good idea. By the sounds of things you've had experience with RC. Would you say a brushless motor upgrade is worth it?
yeah it was few years ago, brushless is amazing, i specifically gave up my Nitro engine for brushless, granted i never used the car after that, i managed to break a chassis, and trying to replace a carbon chassis is £££££
But do it! Make sure you read about the perfect ESC & Motor combo, you'd be surprised how terrible the experience can be if you have mismatched combo.
Also when it comes to LiPO's they are £££ but they're worth the money, ive read horror stories about cheap LiPO's catching fire whilst on charge.
On it's way to me ^_^
