Because of this...
I will quote from my post on futuremark.com
Cheers for any feedback at all, feel free to ask any questions... except how it happen.. im not sure of that myself, all i can do is speculate.
Cheers
Noz
Any possibility of completely replacing the head? Or is the whole thing fubared? I figured this is the best place to askWell after buying a 6600GT today i thought I would fix the mach II and bench the card... well didnt that idea quickly hit the fan, After looking at the head closely i realised that not only had the screw holder from the a64 head was still attached to the screw (Soulder had snapped) but the burning was more extensive than i thought... I decided to investigate futher and break off some of the burnt parts of the head to see that there was a massive gap between the head (black plastic) and the filliant (Yellow stuff) so i can only asssume that air has gotten between this gap and caused the smouldering, something i didnt even think to check with the white plastic seal over the top of the unit... lucky Nventiv are out of business or i would be e-mailing them with this. Anyways the Pictures [wink]
Screw..
Burning..
More Burning..
And the size of the gap between....
Noz isnt a happy man again... [roll]
EDIT- Another thing I dont understand is the sensor is in that region yet it didnt differ in temperature at all even though it was burning away... stupid POS [roll]
Cheers
Noz
