"Polar Claw" X99 rig
Agh, please take the side panel fan off and get a clear plexi replacement window :p
Also your signature is broken, just saying!
What Feronix said about the window dude... I had the C70 before and the fact that the dual 120 fan slots were there, ruined it.
Although, all dat GPU horse power is just insane!... holy moley dude!
You must be one very unlucky guy, maybe it's just the Corsair HX1000W?, as I have an HX750i and it works perfectly :)
Lastly... your sig though. Might just be me, but I find it somewhat difficult to read the specs on your sig itself mate. Like the black and white background is just making the black font a bit out of place, in my opinion though.
The 3 way SLI in the sig though, that is just the boss! :cool:
No, I run an ITX rig with a single intake fan.
The C70 really has ample intake to take care of those GPUs, the side fan is unnecessary imo and just ruin the look for me cause the fan mounts are right in front of the actual components rendering the massive window a bit useless :(
I'm not a hughe fan of the window either, but I can't be bothered. I had prefered there was just the bottom left fan placement.
Or just leave the side panel off completely. should drop temps a few degrees. If Aesthetics is of no concern to you that is.
Actually it's probably better to have the panel on, bringing air in. I ran quad SLI once with two GTX 295 and the temps were lower with the side panel on and a fan directly over the GPUs blowing air in.
Whatever way you try and cut it tri SLI is a real sod to cool. Mostly because the middle card is completely trapped both top and bottom, so the top card suffers also.
I bought a third Titan Black but never fitted it because I remembered the last time I ran three cards stacked (I put a 770 in to drive another monitor). Temps were off the charts.
I actually never had problems cooling my 3 way SLi configurations on air ;)
