spacegrind
Hi all,
I recently built a Sandy Bridge rig with the following specs:
CPU: i7 2600k
Motherboard: Gigabyte Z68X-UD4 B3
RAM: G. Skill F3-12800CL9D-8GBSR2
GPU: MSI GTX 560Ti Hawk
SSD: Corsair Force 3 60GB
HDD: Seagate 7200.12 1TB + WD Green 2TB 5400RPM
Cooler: NH-D14
OS: Win 7 Home Premium 64-Bit
Case: Corsair 600T
Optical Drive: Samsung SH-223B
I set up the system and it ran fine at stock with no issues to speak of. Then I first overclocked it to 4.7GHZ HT On at 1.295Vcore and Level 6 load line calibration, these settings were also stable with no issues to speak of.
Then I went for the big 5GHZ and upped the Vcore to 1.375 with level 6 LLC, it crashed after 50 seconds of LinX and got a BSOD. Since then whenever it boots up it will maybe get to the Gigabyte logo and then turn off and then back on every couple seconds (2-5 approx).
When trouble shooting I found that when I removed the CMOS battery the board would not have the reset issue but when I put it back in the board would keep resetting every couple of seconds.
Things to note:
-I've never pushed more than 1.375Vcore with Level 6 LLC. It MAXES at 1.408Vcore in the BIOS.
-I've never seen the temps exceed 75C under LinX. Under the 4.7GHZ 1.295Vcore settings it topped at 70C and got to 75C under my last settings (5GHZ 1.375Vcore).
Thanks in advance,
Spacegrind
CPU: i7 2600k
Cooler: NH-D14
Case: Corsair 600T
Things to note:
Thanks in advance,
Spacegrind
