Please Help Noob
Bios
Running everything at stock....I have trued uping the voltage stock it sits at 1.45v for the cpu, uh I have tried up to 1.6 I have a Clawhammer so it can take quite a bit. Memory I left everything at stock I do up the voltage to 3.3v.
I had to rebuild on an Asus SLI PREMIUM yeah so I dont havee much for all settings I can tell you that everything was set to stock the last time I tried to boot on both boards, optimized settings were loaded
Are you using the latest BIOS?
Also - In the BIOS try adjusting your memory settings to those you know work - that is to say dont rely on any setting being Auto - manually configure it.
You don't need 3.3v on redline at stock and 1.5v on the CPU should be sufficient..
For an idea of what you should be running at - start your rig up on air then run a64 tweaker and make a note of the settings - use this as your set-up base for your ram in the BIOS.
Mav
I have adjusted everything that is OCCT stable and runs on air and I have everything set at normal and non-overclocked settings and still memory errors....All of this was without the electrical tape as I had said prior to this I dont have the time nor capabilities to test the electircal tape theory.
Honestly If i new someone that would be able to get it to work I would ship it to them and pay them to make it work I just dont have the time currently....
Where u based mate?
Someone here can help I think.
Also, have you tried different memory?
HAve a read on the Asus forums to see if there is an issue with Redline RAM and phase cooling (as acombination I mean a I know it works on air)?
Cheers
Mav
I coming out of Cincinnati Ohio...US ...probably not the best of places considering this is a UK based forum but yeah..and I have tried corsair ram as well no luck...
