I'm going to be selling my precious MachII V2000b, and plan to keep my water loop which is curently cooling the GPU.
System Spec:
ASUS P4C800-E Deluxe
Pentium 4 3.4 Prescott (ES)
X800XTPE/ 6800U (AGP)
OCZ PC4400 - Hynix
WD Raptor
Water Equipment:
2x120 RAD
MCP650 Pump
Aluminium Res
Tubing etc...
Now I want to keep all the hardware above, but may change the rad for one of those little PA160's, so that it will fit in a smaller case.
I'm having difficulty deciding on what to cool with what. I was thinking of running a 172W 24V TEC on the Pressie as it gets very hot, and I like to run fast. But would it be more beneficial to run it on the GPU?
As far as games go I only play CS:S, but also use 3DS MAX/ Solidworks n ProEngineer 3D CAD.
I can't afford to upgrade the components any further (poor student!) or I would chuck it all in the bin and buy a couple chilly1's and dual core processor!
Any suggestions into what components I should air/ peltier/ water cool would be appreciated!
System Spec:
OCZ PC4400 - Hynix
WD Raptor
Water Equipment:
2x120 RAD
MCP650 Pump
Aluminium Res
Tubing etc...
