Hi,
My loop has gunk in it not long after a refill.
From what I'm seeing around the net. It looks to be Plasticizer.
After speaking to Tom, he recommends using white vinegar to clean the rads.
I come across this guide...
And wondered if this is usual practice and effective?
I know vinegar is an acid and I'm not sure when it comes to cleaning the GPU blocks if flushing with distilled will remove all the vinegar?
Should I submerg blocks in distilled water after cleaning and leave them to soak to remove all the vinegar or will this not be needed?
Also I'm thinking about O rings.. will vinegar not effect rubber?
I've already got some...
SysClean Watercooling High Power Limescale Remover & Cleaning Fluid
http://specialtech.co.uk/spshop/cus...e-Remover--Cleaning-Fluid--50ml-pid-5741.html
Should I use that on the blocks and vinegar on the rads?
I need to clean 3 rads and two GPU blocks and the res.
So any advice appreciated
