Hi all just reformatted my computer and i wanted a quick launch shortcut in the task bar and of course windows 7 doesn't allow things that simple so i racked my brain for a few minuets and fond a few things on Google and this is what to do.
First off right click on your desktop and chose "NEW" and then select "TEXT DOCUMENT"
Name the text document what you want but make sure that you change the .txt to .exe
if you cant see the .txt when you are renaming the file you first need to make windows show file extensions.
To do this go to the start menu and type "SHOW OR HIDE FILE EXTENSIONS" this should bring a window up like this.
Untick "HIDE EXTENSIONS FOR KNOWN FILES TYPES"
if you have done all the steps correctly this is the way the file should look.
Next right click on the file you have just created and create a shortcut on the desktop.
You now should have two files of the same name on the desktop. Right click the one with "SHORTCUT" at the end and then click properties.
Hear is where you can change the icon image.
Once you have done that click ok and the right click the file again and select "PIN TO TASKBAR"
The icon will now appear in the taskbar.
Now that the icon is in the taskbar we can now link it to a hard drive. to do this we need to change the path.
Do this by right clicking on the icon in the taskbar and selecting properties.
The same window as before will appear. Where it says "TARGET" change it to the directory of the hard drive. In this case i will be changing it to "D:\" (without the quotes)
Click ok and if all the steps were followed correctly it should link to the file you specified.
If you need any more help with this matter just PM me or reply to this post and i will get back to you as soon as possible.
