pimp my advent3312 ?
i have a hyper 580 watt supply i think its that
what u think to this i like the look?
Code:
http://www.ebuyer.com/customer/products/index.html?rb=17499961336&action=c2hvd19wcm9kdWN0X292ZXJ2aWV3&product_uid=102978
Rofl, why'd you put that into a code box? w/e, that case is a favorite among many. If you can afford it easily enough, I'd say go for it. Top quality, nice looking case.
soz about code box used to doing it on other fourms where they dont like live links.
i just hope card works this time or its all waste of money.
freezer 4 p4 heat sink inserted(bigger than i thought it would be),case,hyper 580watt supply and geforce xfx 7800 gs extreme working fine yipee. cant belive how much space there is
overclock by 5 percent.
how much should i overclock it to? its at 2.8ghz now
only thing that didnt work is ddr 333hz 1g cards pc 2700 still inserted but no size change
got 2x 512 and 2x1gb
You could always test your overclock with F@H, that'll test the stability for sure...one of the best ways imho :D If you see premature completion of WU's or errors from Windows you know she ain't stable. The F@H client runs your cpu AT 100% load, and is very reliant on memory stability. We'd be honoured to have you fold for our team (43461), you'll find all the help you need Here, or from members of the forum. Grats on getting your issue sorted mate, and tell everyone you know to check out OC3D forum. :)
only thing is when i push it to 30% it says windows/config needs repair but just rebooted and put it back to 20%.
what that about?
