For anyone who's seen my sig and random rantings in the shoutbox, you'll know I have a Lian-Li PC-A05B on the way
I've started but abandoned so many projects in the past, and I'm not gonna let that happen this time!
This case is well known for having a heat pocket towards the top of the case, so I'd like to cut out a 120mm fan port at the top to let the heat out. At the same time, I may put a window on the side of the case as well.
That being said, I don't have the tools to do this
I've tracked down two Dremel kits, both for about $79 CAD, and I'd like some opinions on which would be the best to get, and if anyone could recommend some accessories to buy
Here's the two:
- Dremel 300 Series Kit (Official Page)
- Dremel MultiPro Kit w/ Flex Shaft (Official Page)
Which would be better for doing this kind of work or is of better value?
Thanks
Here's the two:
Thanks
