AlienALX
Well-known member
That the GPU's will cook is really a misconception, their Temp will rise by maybe 5°C. I have it tested similarly but only having a R9 295X2 once blowing hot air into the case and once having the rad mounted to the fan mount facing outwards. My CPU temp went from 55°C to now 62°C. That's really marginal also if you consider that a CPU will never put out 500W like the 295.
You are running a Raven, right? which is basically a wind tunnel. I am assuming your rad is on the floor directly under the 120mm in the top of the case expelling the warm air?
