Cigarjohn
I need some advice from PC builders. I'm a little confused. Intel's support sucks. What a bunch of idiots, after two support techs and 1.5 hours of wasted time, they seem to not know their butts from a hole in the wall. And it seems no one builds computers that work at Intel. "GO FIGURE"!
Anyway, back to my questions:
I'm looking at building a new system for gaming and light to medium heavy video editing. Now I'll probably use the i7-7700k on the z270 Chipset. Most likely the Asus z270 WS or possibly the Asus X299 APEX or Maximus VI Extreme with the Intel 7800X.
Also will be using one 1080 TI in 1440p with a possible future expansion of SLI in the future but not know.
So getting to my question. The i7-7700k has 16 PCIe lanes and the chipset has 24 PCIe lanes. So does this mean I have a total of 40 PCIe lanes to work with.
I'm asking this question cause I would like to run dual video cards in x16 mode, one M.2 in gen 3x4 in PCIe mode and one x4 sound card. These combined equal 40 PCIe lanes. So my question is if you need more PCIe lanes than the processor can handle, will the chipset kick in with the remainder PCIe lanes needed?
Also, do SSD's and your Optical Drives use PCIe lanes as well? The SSD's are Sata 3 and the Optical is a Sata connector.
Also I noticed the chipset specs state it also uses six Sata 6G ports and fourteen USB ports. Are these an addition to the 24 PCIe lanes?
On RAM, I think I'll be going for 2400mhz at 32 gigabytes.
Thank you in advance.
