looking at all these wires and keeping them straight and trus is one big PITA!
the question i pose to the group:
using a single rail PSU, i should be able to gang power all 6-pin 12v+ and 6-pin
12v- by a single solid copper wire 10/12gauge or like....
making a jumper on each pin location for the 12v+ and 12v- to connect coresponding
terminals to. so now instead of:
1x 6-pin i'll have two wires not 6
2x 6-pin i'll have two wires not 12
1x 6-pin and 1x 8-pin i'll have two wires not 14
same as well on the EPS 8-pin and the 24-pin 8wire instead of 24..
noting that on the 8-pin, the "alternate" 2-pin is a double ground to make the Overdrive
in CCC function and cant see what it controls on the nVidia side..
looking to streamline the cable management of a PSU.
my basic take away is on a single rail PSU there are 8 gangs:
common (ground/earth) (motherboard power, pci-e power, EPS power and peripheral power)
3.3v+ (motherboard power)
5.0v+ (motherboard power and peripheral power)
5.0v sensing (motherboard power)
12v+ (motherboard power, pci-e power, EPS power and peripheral power)
12v- (motherboard power)
power_on_OK (motherboard power)
PSU_on (motherboard power)
anybody got any 'sperience in the 6-pin in 8-pin location?
airdeano
airdeano
