Robi_G
Project is to build a case from scratch and to also make a temperature management system for it. Been going on for a while now but only just joined the forum.
I'll post a couple of the first design pics so you get the idea but there are so many.
Probably best if the story is in pictures.
At first it was going to be a 3 tier case with the top part removable if radiators weren't being installed, but that would have made it massive.
http://i1260.photobucket.com/albums/ii569/Rob_Gower/Custom PC case/revisedChassis.png
Not the final cuts, they were scribbled on a scrap of paper.
http://i1260.photobucket.com/albums/ii569/Rob_Gower/Custom PC case/Cutoutsforbody.png
Bit later on, after the circuit had been made (no pics of that yet), decided to make the panels.
http://i1260.photobucket.com/albums/ii569/Rob_Gower/Custom PC case/P-0023_zps14216bf0.jpg
With some stuff in
http://i1260.photobucket.com/albums/ii569/Rob_Gower/Custom PC case/P-0032_zps03ed72d1.jpg
Here is the link to the photobucket album, http://photobucket.com/custompccase
hope I havn't gone over the picture size limit
Colour scheme will be white and orange.
thanks,
Rob
With some stuff in
thanks,
Rob
