Hello,
my PC had two memory sticks with 2 GB RAM each. I had two free slots and installed two more sticks with 4 GB RAM each.
When I started the PC, it started the fans and the Power-LED, but stopped all of a sudden. Then the PC started again and stopped again. He did it several times and did not really start to boot. The monitor screen remained dark all the time, there was no image on the display.
I thought, that there is something wrong with the new Memory and removed it.
When I started the PC again, it showed the same behaviour as before. No image on the monitor screen, no boot process, only the fans started for a second or two and the Power LED went on and off.
I can not recover the PC, the DVD-Drive does not open and the PC does not start the BIOS or boot process. Any idea, how I can handle this and resolve the problem?
My PC specs:
Motherboard: H67MA-USB3-B3
Old Memory: 2 x 2 GB Kingston (?) DDR3 RAM with 1333 MHz
New Memory: 2 x 4 GB Corsair XMS3 DDR3 RAM with 1333 MHz
CPU: Intel Core i5 2500 @ 4 x 3.3 GHz
GPU: AMD Radeon HD 6870
Any help is appreciated, thank you very much in anticipation.
Zazl
My PC specs:
Zazl
