Hey guys just hoping someone can tell me if these parts are compatible/ if its a good build for high end gaming for the next 2-4 years.
[font=Verdana, Arial, Helvetica, sans-serif]Intel Core i7 2600K
(http://www.pccasegea...oducts_id=16416)[/font]
[font=Verdana, Arial, Helvetica, sans-serif]ASRock Z77 Extreme4 Motherboard
(http://www.pccasegea...oducts_id=19867)[/font]
[font=Verdana, Arial, Helvetica, sans-serif]OCZ Technology ZT Series 750W Power Supply
(http://www.pccasegea...oducts_id=19351)[/font]
[font=Verdana, Arial, Helvetica, sans-serif]Enermax ETS-T40-VD CPU Cooler [/font]
[font=Verdana, Arial, Helvetica, sans-serif]([/font]http://www.pccasegea...oducts_id=18648[font=Verdana, Arial, Helvetica, sans-serif])[/font]
[font=Verdana, Arial, Helvetica, sans-serif]or
CoolerMaster Hyper 212 EVO CPU Cooler
([/font]http://www.pccasegea...oducts_id=18670[font=Verdana, Arial, Helvetica, sans-serif])[/font]
[font=Verdana, Arial, Helvetica, sans-serif]G.Skill Ripjaws X F3-10666CL9D-8GBXL (2x4GB)
DDR3 (http://www.pccasegea...oducts_id=16509)[/font]
[font=Verdana, Arial, Helvetica, sans-serif]EVGA GeForce GTX 670 2GB
(http://www.pccasegea...oducts_id=20210)[/font]
[font=Verdana, Arial, Helvetica, sans-serif]Crucial M4 SSD 128GB
(http://www.pccasegea...oducts_id=17685)[/font]
[font=Verdana, Arial, Helvetica, sans-serif]Seagate Barracuda 2TB ST2000DM001
(http://www.pccasegea...oducts_id=19554)[/font]
[font=Verdana, Arial, Helvetica, sans-serif]LG GH24NS90 24x SATA DVD-RW Drive OEM
(http://www.pccasegea...oducts_id=19580)[/font]
[font=Verdana, Arial, Helvetica, sans-serif]Microsoft Windows 7 Home Premium 64bit
(http://www.pccasegea...oducts_id=17003)[/font]
[font=Verdana, Arial, Helvetica, sans-serif]Thermaltake Overseer RX-I Case
(http://www.pccasegea...oducts_id=18313)[/font]
[font=Verdana, Arial, Helvetica, sans-serif]Questions:[/font]
[font=Verdana, Arial, Helvetica, sans-serif]1. Will I need something like this :
http://www.pccasegea...oducts_id=17887
to plug the USB 3.0 plugs straight into the motherboard or does someone know if they are already the 'correct' plug to insert onto a port on the motherboard. I ask as I don't want to have to route them out the back of the case and into usb ports on mother board.[/font]
[font=Verdana, Arial, Helvetica, sans-serif]2. How do I apply thermal paste correctly so that it is not too thick or thin and spread out evenly?[/font]
[font=Verdana, Arial, Helvetica, sans-serif]3. On another forum someone recommended to get a Intel Core i5 3570K, so maybe an equivalent i7 processor would be the way to go?[/font]
[font=Verdana, Arial, Helvetica, sans-serif]Note: This costs about 1720 and I don't want to go more than 1800 so if there is a better processor out there in that price range please feel free to recommend it
[/font]
[font=Verdana, Arial, Helvetica, sans-serif]Thank you very much to anyone who can help[/font]
