---'Parvum KRAIT'---
imersa
GKCUzFzOuq1IPCwEp814S7xZCdfx6_wxAqhdY0YG_MbR=w700
Hi everyone. We have been very lucky in getting a chance to work on further projects for MSI. This time in a larger ATX sized Parvum case. Giving us a chance to explore the larger form factor first hand while showing off some awesome MSI hardware.
This build is possible with the support of MSI, Hyper X and XSPC.
Case - Custom Parvum ATX
CPU - Intel Unknown
Motherboard - MSI Z97S SLI Krait Edition Intel Z97
Memory - Hyper X Unknown
GPU - MSI GTX 960 2GD5T OC
SSD - Hyper X 3K
PSU - Silverstone Strider 1500W
lW7OwWbjPjP0-icwU-W7vLdabSrACsHOkwGXu23vjJOp=w700
First we will take a look at the core components for the build. Naturally these will form the theme on which we build around, complementing the harsh aesthetic contrasts of MSI's hardware.
BWi2mmYmwDP_N-DvCn9ScQ1QoAggWRAcfmBGcPPbE1ej=w700
PxFWWr3mN5_waSEAymg3Iaa5s7n0Ea_sDf6wDoB3TE_8=w700
i9MbB1vNyGc-KebtnDsSatb9aGXbQI1njcaTykuOVY4n=w700
0AjHn4WNmzz7KR9FgSJoiciB5CYz5_JzbBWNKGwHJhwR=w700
iU5wOUJz-bcglnT_uA5VhlZjR21dIHjaLAweEQWNHIre=w700
xT--1dprsfB2u8c8CAg1F9nsd8A0_35ipwXd17L0r06-=w700
dlJqY8xuu4UxEHza5ZTk_F_gLtvW-dg7rxxh3yOgwUQE=w700
QLOT0kTpzsnY-XbMfygZls-FJkmC4R0XZ3cCUOvUJUrn=w700
IHwK8yia8Lm3uWug-XuGr26OXRuQZyuJ5OseiFm_QFi5=w700
BUYU23c1dOLulj3B2HnUgDGc1xa-nvo4oONPBFZhteUw=w700
qRPAJDN9bYpAkXGe8HqgYI2O3U1_RZgzM4BT0xtUyvh7=w700
Not giving too much away here but stay tuned and all will be revealed.​
Finally we will see the ATX Parvum!
The ATX Parvum can take several forms, ranging from Magnus to what we will do for this project. This will be an opportunity for us to build in one, in a slightly less extreme way, and that will certainly influence what we do with larger form factor cases in the future. ;)
Loving how it looks and the pictures really stand out... the snake on the motherboard made it all abit more "Uhmff!" so to speak :p
Although, that 1500W PSU?, is it just me or? :huh:...
We do have quite a lot of fans, 300W for the system, 10x100W for the fans, 25W for the pump, 25W for the LEDZ, little 150W overhead to give the PSU a chance... but your right we probably could do with another one just to be safe.
lol jk, going for some killer overclocks.
Ok, legit this time of the PSU's we had ready to go into builds it made sense to put that in this one where there was plenty of room and it would look nicely proportioned.
Lets take a look at all of the water cooling components we shall be using in PARVUM KRAIT. With literally several black nickel fittings from XSPC and EKWB to hand building a clean and distinctive loop should not be a problem.
vu5X9L6dnXKTvdl24CKhGH3FkNMbBN-Os2CBVIY4JnKB=w700
sDkrxc_nLpUT26yjSr3KxI0_sWoHNt1IdDFafSi4TENe=w700
UFPeMIeQxNEAhQPg9eU1xWXPOwfpgoQquhoLXJ1NvB52=w700
Bs8mY5Xtx2S60CroIyEixi5Yqn3jGCMEeP7capOuinsl=w700
What else but gloriously white XSPC AX radiators to bring the harsh KRAIT contrast through into the rest of the case.
cfxpfj-DKowXGKxxlub3MaMGuzw3qwUWmU-xPD3T0_Hg=w700
5pODyu37uaj5ip2EnCEWsOm3o1nz_EQqJNlSdSQ5X-mx=w700
6LZIOozfXw3D-ugKMQHeudSF2ZF5zKvUR6ZqqytMkP5O=w700
The pump which shall be used is an D5-Vario with a stealthy black XSPC acetal top.
BlgiuhcePdmVPtYktrLGriMGiJNkAwhNnYjkL5KlHTiY=w700
With such an expansive radiator area it would probably run quite happily with no fans, but just in case we found 6 or 10 Noiseblocker NB-eLoop's
Sz_J7LDrT_fyCbjDYuyiRUDb9tegG1WpRTcqXcanx9rq=w700
LtRwWBJZqxQ3V2pboVcJ1mr1Xz7QeslCHVMuBN0wAz55=w700
Something missing here...
_3d0T3OScos6kAz0d4SOqdUB2aFQvZB_u5d39oDHGKRT=w700
bMEvvTiYS_cGgdolbWgNT_P-9BKySBRVp4c9Gjry56-G=w700
That just leaves blocks for the memory and CPU, XSPC's raystorm blocks complimented the motherboard well while not over-powering the standard heatsinks and detailing. The graphics cards won't be including in the loop as we wished to retain their KRAIT branding.
pOLzs-NZMRPtsoOQ2iKcPGDLcTt_-UPbcaBuc-_KHTNR=w700
_NrVt_5GEb0CjtNTNOL5pqF3eKocYTIsoYx7Z59PyR-X=w700
Definitely no case hints to see there ^ this might just be another one though ;)
nLUlNbspvhb28716O8SqDYMUqnGPop4Yt2DDl8cENWOO=w700
Here comes the case... :eek:
-XQM-Lg01M74Bp1LPENWQJWq82gjdqtNGa9IrClDLfgN=w700
No Parvum would be complete without a little bit of HyperX, somehow looking even better in black and white we have a 3K SSD for PARVUM KRAIT.
aTrXE8mbp5PdCNq96sULRTR28z0_smT_N0SHk6i6WOY-=w700
hbI4PEs6M5RX9leepk6CB3tHLvxoQ1Z5iUQqyVW49tzI=w700
The moment you've all been waiting for, a relatively gigantic Parvum of the ATX form with plenty of room to accommodate all of the watercooling gear.
Qf5vRQbMmaVGUlAI6AI2ocka_TrRKZMTR8-yiGUuFkGl=w700
qJ1MirNg4C5W4dgl1hJuF83EEDWH6h-7PCOt1IHH8G2l=w700
xe6Ku12jmj8oW-ke4ejjM7xnsHzZJhMcNrs1dFXijvRI=w700
FdmAAzTI0QfFYvpR842mSz99O2hHS9-hoUKYn93r18bM=w700
mNSfU-E8qFY9qz9d2hbAxYATQLa-_K3ip3r6s95mY8Ag=w700
jLKXvcBByjKP8ZG_eQg8eYZMrply3k7PpVifynGveh_A=w700
Time to bring in the hardware...
rEcOK6wK5QYTmJdVoXQKCjEKneqSbeS8Pyv40ykp9B79=w700
6XfhetrZopVeRlXlzd1mV1ZLUEzaiyfwBKVtQmOege1n=w700
pKGTI1jYMsNYK83djEJMg7RRckOzdIykoYs9ke7LQNqA=w700
Push pull, just because we co... I mean for the substantial thermal performance benefits.
mSHVy9cPPst07tRZG_-H6vE9-PNWCCSZ9-AtdQehXQsk=w700
DPQelyzYXhko0JMzKshmXGFes-lVskGLoP_GllUlLTAU=w700
Thanks for all of your positive comments, we can't wait to bring you even more, naturally in black and white.
With all of the parts selected and neatly positioned in the case it was time to plan out the loop and prepare to unite the components with coolant. At this point the pump and reservoir were propped up and we experimented with placement of fittings to carry off the distinctive Parvum rigid acrylic style.
jgy5WuUV-j-FLGttMqXKNi7RR-HV_yfHQI7WfHm-FTKM=w700
w5W8kJHecXbBlRnrP1pUI9WprkMvAnQNPbTZxJF_CdSP=w700
It's not just as simple as smashing in loads of rotaries, much consideration was given to symmetry and balance.
F-gMe5JCNykoHrfHeRRN3eDZ31JvqD4EwRHAIltOX-5U=w700
Peiw0W2F31_Yh_s39gm3KnuEYYZnCm64uvnvNJLyr4da=w700
After getting to positions we were happy with the pump was mounted directly to the rear panel of the case.
C8oUbt9ZRN3nICP2-iOKr_U0F7gURclElYuanVqiUd01=w700
aNjcagJlOZTP1E1tGmIo1m_bLDwHKiM_4-n6ic2xaXOz=w700
_JZ1NMUqgq-_hp7G0phu3JxVHgVOAljSK17sEfr0uZoU=w700
Next time we will be tubing the loop, mounting the reservoir and hopefully getting on to some leak testing. Plus there are a few loose ends to be wrapped up in the back of the case.
PS. Whoever can spot the huge oversight (which was totally done on purpose) will earn a teaser for your forum.​
Only things i can see are 1. The 2 fans and the rad are missing the black covers over the bearing section and 2. the pump is missing a stop cap.
But i have been up for over just short of 36 hrs so will have another look lol.
We are waiting for some more matt black fan stickers but that's not the one. Your very close with the stop cap, a commendable effort for such awakeness.
There's a lifetime's wages worth of fittings in those boxes...
Still don't understand why the markup on those things is so utterly stupid compared to the bom cost. But meh..
This is looking lush.
Looks to me like you're going res-cpu-ram-pump-rad instead of res-pump if I see this corectly according to the angle of the fittings, is that the 'oversight'?
EDIT: oh nope it's the other way around, res-rad-pump-ram-cpu, the middle port of the pump is the inlet!! :p
