Devastator0
So, I've been tasked with trying to put together a decent, and what I hope to be a long lasting PC for a friend's parents. As per the sticky on this section of the forums....
• Where are you located? Sydney, Australia
• What is your budget? $500AUD-$700AUD
• Will you need a monitor, keyboard, and/or mouse included in that budget? Not at this stage.
• Shall you be requiring an OS? Yes
• What will you be using this rig for? Non-Gaming Rig. Home Use. Office, Internet, etc etc
• If gaming, what resolution will you be playing at? N/A
• Will you be overclocking? No
• Do you need a full build or will you be reusing some old parts? Full Build
I currently have the following parts scoped out:
Case - BitFenix Merc Alpha Mid Tower Case
PSU - Corsair CS450M Modular 80 Plus Gold
Mobo - ASUS H97M-E Motherboard
CPU - Intel Pentium G3420 Haswell Refresh
RAM - Corsair Vengeance Pro CMY8GX3M2A1600C9 8GB (2x4GB) DDR3
GPU - Integrated Intel HD Graphics
HDD - Seagate ST1000DX001 Desktop SSHD 1TB
I would welcome any advice or better suggestions.
Thanks all
Thanks all
