I would appreciate if you guys can check my components in terms of compatibility and make any suggestions to my water cooling list. I have spent a considerable amount of time selecting each part that would best suit my build budget (without compromising too much).
I am intending to water cool my CPU only as I will be using the Gainward GTX580 Phantom GPU. I will be putting my water cool loop in a Corsair 650D case so I am not sure if the rad with fans will have enough space?
I have opted to buy a 2 channel fan controller since I will only be controlling the two 120mm fans. The other fans on the case will be controlled via the switch that comes with the 650D case.
Thank you
- EK Supreme HF Copper Gold edition CPU Block
- XSPC X2O 750 Dual 5.25” Bay Reservoir Pump
- PrimoChill PrimoFlex tubing ½” ID ¾” OD
- 4 x Bitspower G ¼” Matte Black Dual Rotary 45-Degree Compression Fitting
- 2 x Bitspower Matte Black Ultimate G ¼” Rotary Compression Fitting
- Black Ice SR1-240 Radiator
- 2 x Scythe Gentle Typhoon AP-15 120mm
- Scythe Kaze master Ace 3.5” 2 channel fan controller
- Gold PrimoChill ICE Non-Conductive Liquid Cooling Fluid
Thank you
