Edgeyforsure
okay so im a little confused, i have an asrock extreme 9 x79 with a 3930k
now coming from an AMD background and never having the Black edition CPU's im used to overclocking via FSB, and all these new terms really baffled me, i figured i would use the preset "4.6ghz" as it was close to the 4.5 i was aiming for, which upped the power levels slightly, and also put +0.2 on the offset volts, which was fine.. highs of 84c it was stable so i started dropping the offset volts..... im currently sat at +0.020 and its seeming stable as a rock.[all other offset volts were tested aswell, i didnt just knock off 0.18
] (stable as in, running different games with prime in the background for 12ish hours as its my days off)
the "level" is set to level 3 medium, as well, thats what it set it too, i dont really understand that too well, shall i just keep dropping the offset volts? its currently at about 1.33v @75c max, am i missing something or is it really this simple
its a revision C2 cpu which i understand clocked well but, these volts are getting silly low
