Catch22.ian
Hi all,
I have a strange issue with my system since I brought it from aria.
at first I thought that it was the system board - and have RMA'd it twice - ARIA have tested and found no fault.
I've been playing with the over-clocking settings trying to get it to work properly at 4.4GHz.
System Specs below:
CPU / Processor:
Intel® Core™ i3-550 Processor
CPU Cooler
Coolermaster Hyper TX3 CPU Cooler
Motherboard:
GA-H55M-UD2H v1.3 F11 Bios
Memory:
4GB Mushkin (2x2GB) DDR3 1333MHz 9-9-9-24 Silverline
Hard Drive(s):
Samsung HD753LJ 750GB & Samsung HD103SJ Spinpoint F3 1TB
Graphics:
EVGA GeForce GTX 460 SuperClocked 1024MB EE (External Exhaust)
OS:
Windows 7 64bit
Case:
NZXT Beta EVO
Power Supply:
520W Antec High Current Gamer HCG-520 ATX2.3
The problem I've got is that I can only get the system over-clocked to 4.4HGz without a G/Card in the pci slot as you can see below :
http://valid.canardpc.com/show_oc.php?id=1890080
The most I can overclock with the G/Card installed is 3.6Ghz :
http://valid.canardpc.com/show_oc.php?id=1888872
When I try with the g/card installed - my p.c. just won't boot up - the fans start - but that's about it.
I think it may be that the PSU (Antec 520W) isn't powerful enough - has anyone got any-more suggestions??
System Specs below:
CPU / Processor:
CPU Cooler
Motherboard:
Memory:
Hard Drive(s):
Graphics:
OS:
Windows 7 64bit
Case:
NZXT Beta EVO
Power Supply:
