I have had this CPU for a while and tested it out a bit but I just recently realized that my case prevents me from doing a decent overclock. The problem is the airflow, or more like lack of it, so now I have the side open which has already resulted in a performance and stability increase but the real question is, how far can it go?
I have a Khuler 620 with the rad in the bottom sucking air in to the case...which is by the way the only "extra" fan slot in the entire case (retard design). The stock fan sucks pretty much...that's meant in the bad way as in it sucks at sucking...and I have got an option, I can take the stock fan and throw it in to my server (which I don't use that much) and take the servers fan. There's a 120mm Delta (FFB1212EHE-F00) fan in the server which sounds like an airplane but then again it pushes extreme amounts of air too -> 190CFM @ 4krpm.
How much do you think that the CPU can handle? -I have had it temporarely up to 4.8GHz but with that there's...there was huge stability issues since there's no airflow.
What's the most you have seen this CPU go up to and with what sort of cooling?
