CACHACEIRO
Hello guys
i've been running my pc in idle clock for about 1 year/ 3 months and its been running with troubles in FPS for some games.
my PC config is:
CPU i7 950 Bloomfield
MOBO - Asus Ramapge 3 Gene
RAM Dominator GT 2000 Mhz corsair
Cooler CPU H50 method push/pull - Idle temp aroudn 39 - 43 (My weather region is hot hot hot)
SSD Intel SATA II AHCI 80 GB x-25 M
HDD SATA II WD 1 TB caviar Black
PS - HX850W corsair
GPU - GTX 480 EVGA SC
Please help me to overclock my CPU for only to use the 2000 MHZ of my Ram where I only use 1600 MHZ at moment.
Target CPU Frequency 3,6xxMHz
Target DRAM Frequency 2000 MHz
LN2 Mode: Disabled***
QPI Loadline Calibration:Enabled***
Sync Mode [Enabled]
AI Overclock Tuner [Manual]
OC From CPU level Up [Auto]
CPU Ratio Setting [21.0]
CPU Turbo Power Limit [Disabled]
>CPU Configuration----------------------------
C1E Support [Enabled]
Hardware Prefetcher [Enabled]
Adjacent Cache Line Prefetcher[Enabled]
Intel® Virtualization Tech[Enabled]
CPU TM Function [Disabled]
Execute Disable Bit [Enabled]
Intel® HT Technology [Enabled]
Active Processor Cores [All]
A20M [Disabled]
Intel® SpeedStep™ Tech[Enabled]
Intel® C-STATE Tech [Enabled]
C State package limit setting[Auto]
BCLK Frequency [xxx]
PCIE Frequency [xxx]
DRAM Frequency [xxx]
UCLK Frequency [xxx]
QPI Link Data Rate [xxxx]
Memory Configuration Protect[Disabled]
CPU Differential Amplitude[Auto]
CPU Clock Skew [Auto]
IOH Clock Skew [Auto]
------------ Extreme Engine Digi+ ------------
Digi+ PWR Mode [T-Balanced]
PWR Volt. Control [Auto]
Load-Line Calibration [Full]
CPU Voltege OCP [Enabled]
CPU PWM Frequency [Auto]
Extreme OV [Disabled]
Extreme OC [Auto]
CPU Voltage xxxx
CPU PLL Voltage xxxxx
QPI/DRAM Core Voltagexxxx
DRAM Bus Voltagexxxx
>DRAM REF Voltages----------------------------
DRAM DATA REF Voltage on CHA[Auto]
DRAM CTRL REF Voltage on CHA[Auto]
DRAM DATA REF Voltage on CHB[Auto]
DRAM CTRL REF Voltage on CHB[Auto]
DRAM DATA REF Voltage on CHC[Auto]
DRAM CTRL REF Voltage on CHC[Auto]
IOH Voltage 1.244[Auto]
IOH PCIE Voltage1.508[Auto]
ICH Voltage 1.111[Auto]
ICH PCIE Voltage [Auto]
---------- Spread Spectrum Control -----------
CPU Spread Spectrum [Disabled]
DRAM Spread Spectrum [Disabled]
my PC config is:
PS - HX850W corsair
Sync Mode [Enabled]
A20M [Disabled]
Extreme OC [Auto]
CPU Voltage xxxx
