right now speedfan is saying temp1 is 40 temp2 (CPU) 47 and temp3 127 but it said that from the beggining so i assume thats a mistake? i think while i was playing css the cpu temp hit 55, xms said my limit was 60 so hopefully thats all gravy
yea i bought my case (thermaltake armour) because i intended to buy the asetek water cooling kit, the triple rad one but i know ur going to tell me that pre-made kits are rubbish lol. would the next step be water cooling ?
Yeah, 59 is pushing it. You aint gonna do any damage as the chips are designed to go well up into the 80's without dying - however - p4's have thermal throttling which kicks in at something like 65, so you wanna stay lower than that for sure.
Good air cooling (xp-90c + Tornado Fan) will kick the crap out of almost all pre-made water cooling kits, and will generally be quite a bit cheaper too.
Cool looks good. Pics are a bit hard to make out tho, and i can't work out where they will be putting the hard disk drives (because on the stacker, the hard disk tray takes up 3 drive bays).
Also, don't go with that w/c system they put in there. get something like this:
XSPC 120mm Tripple rad (Cheaper than BIX and same performance)
1/2" Tubing (not that pencil dick stuff that the kits come with)
