steveyg_uk
I would like to know the suitable settings for overclocking my memory and motherboard please. Im trying to reach at least 3.4 or even 3.8 (as other people have without using water cooling) The specs are detailed below;-
Processor = Intel Core 2 Duo E6600 Retail
Motherboard = Gigabyte GA-965p-DS3 Rev 3.3 775
Memory = OCZ 2GB kit EL DDR2 PC2-6400 / 800
Power Supply = 500W PSU
Cooling = Akasa AK-960E Heatpipe Cooler
Arctic Cooling 12 System Fan
2 x Case Cooler Exhaust Fan
Case = Aria Gamer DarkStar
Storage = 2 x 320GB Seagate Barracuda SATAII 16MB 5yr warranty Raid 0
1 x 500GB Seagate Barracuda SATA-2 16MB
Here is a list of my MIT settings within the BIOS;-
Robost Graphics Booster - AUTO
CPU Clock Ratio - 9
CPU Host Control -ENABLED
Cpu Host Freq -FSB333
PCI Express Freq - 101
C.I.A.2 - DISABLED
System Memory Multiplier -2.5
Memory Freq Mhz - 833
System Voltage Control
DDR2 OverVoltage Control - 0.2
PCI-E OverVoltage Control NORMAL
FSB OverVoltage Control NORMAL
MCH OverVoltage Control NORMAL
CPU Voltage Control 1.4
Normal CPU Vcore 1.35
High Speec DRAM DLL Settings = OPTION1
Dram Timing Selectable = AUTO
CAS Latency Time = 5
DRAM RAS to CAS Delay = 5
DRAM RAS Precharge = 5
Precharge delay (tRAS) = 15
ACT to ACT Delay (tRRD) = 4
Rank Write To READ Delay = 3
Write to Precharge Delay = 6
Refresh to ACT Delay = 42
Read to Precharge Delay = 3
If someone could please shed some light my way it would be very much appreciated.
Thank you.
Steve
CPU Clock Ratio - 9
C.I.A.2 - DISABLED
Thank you.
Steve
