overclock 3570k on stock settings
It's ok dude - yes your temps are safe.
You can do a lot more though if you want to - take the volts off auto and raise the multi. Go for a max temp of around 80C.
all it comes down too..
hACB3A1F4
Hi just great:) #3 Did found your guide earlier online
but learned that you can reach 4.2 on stock voltage:)
Anyway thanks a mill for your input to a newbie
with overcloking. Don't wan't to push it any further just yet:)
jangodog
