Hey, I invested heavily on a very good water cooling loop for my rig at Christmas. However I am sorry to say that I do regret it; mostly due to the performance not being what I thought it was going to be (Although my CPU also contributes to this due to it being very bad at overclocking) and also due to the sheer hassle I have had with it.
Anyway now to the problem. This evening I went out with some friends and stupidly left my computer on for the entire time (not something I would normally do) Upon coming back I started up a game and found it to be slightly laggy which was certainly odd as it has never been so before and my rig should technically eat it for breakfast.
I then lent over and had a quick look over at the front of my rig and noticed that my fan controller's screen was black, I touched a button and it sprung to life...along with the fans. I quickly noticed this and touched the top of the case which was almost to hot to touch, so I quickly shut down the system.
I whipped off the side of the case and found an exceptionally hot area. I quickly took the other side off and held a fan at the bottom to cool it down. Once it was cooled, which took around 15 mins, I inspected the innards to see if there had been any damage.
Now for the main problem: From what I can see the entire water cooling system has been effected. Firstly all the tubes have elongated and widened, also due to the elongation one of the tubes has kinked beyond repair. All this I guess was down to the heat. Another problem I have discovered is that If I turn the rig on two of the three tubes suddenly get a LOT wider, as if water is blocked somewhere. I have held the kinked tubing flat so it is completely circular, but the other tubes still widen.
I am rather irritated at the moment as you can imagine and am really tempted to simply rip the water cooling loop out and just shove a Noctua in there.
Could you wise people please advise me on what to do from here on? and could you please advise me on the tubing problems?
Thanks a lot if you have even made it down here
and as always, all advice is welcome.
