Type: Blend - stress CPU and RAM Min: 8 Max: 4096 InPlace: No Mem: 1791 Time: 15
CPU: 2625MHz FSB: 375MHz [375MHz x 7.0 est.]
1:Starting MBMStarter.dll...
1:Started MBMStarter.dll: 1
30/05/2007 15:15 1:0/0
1:Temperature: Case: 33.00
1:Temperature: CPU: 44.00
1:====================
Launching 2 threads...
1:Using CPU #0
2:Using CPU #1
1:Beginning a continuous self-test to check your computer.
2:Beginning a continuous self-test to check your computer.
1ress Stop to end this test.
2ress Stop to end this test.
1:Test 1, 4000 Lucas-Lehmer iterations of M19922945 using 1024K FFT length.
2:Test 1, 4000 Lucas-Lehmer iterations of M19922945 using 1024K FFT length.
1:1 minute
1:Temperature: CPU: 55.00
1:2 minutes
1:Temperature: CPU: 56.00
2:Test 2, 4000 Lucas-Lehmer iterations of M19922943 using 1024K FFT length.
1:Test 2, 4000 Lucas-Lehmer iterations of M19922943 using 1024K FFT length.
1:3 minutes
1:Temperature: Case: 34.00
1:Temperature: CPU: 58.00
1:4 minutes
1:Temperature: CPU: 59.00
1:Test 3, 4000 Lucas-Lehmer iterations of M19374367 using 1024K FFT length.
2:Test 3, 4000 Lucas-Lehmer iterations of M19374367 using 1024K FFT length.
1:5 minutes
1:Temperature: Case: 35.00
1:Torture Test ran 5 minutes 40 seconds - 0 errors, 0 warnings.
2:Torture Test ran 5 minutes 40 seconds - 0 errors, 0 warnings.
1:Execution halted.
2:Execution halted.
CPU: 2624MHz FSB: 375MHz [374MHz x 7.0 est.]
31/05/2007 21:01 1:0/0
1:Temperature: CPU: 46.00
2:Using CPU #1
1:Using CPU #0
1:1 minute
1:2 minutes
1:Temperature: CPU: 57.00
1:3 minutes
1:Temperature: CPU: 60.00
1:FATAL ERROR: Rounding was 0.5, expected less than 0.4
1:Hardware failure detected, consult stress.txt file.
1:Torture Test ran 3 minutes 48 seconds - 1 errors, 0 warnings.
1:Execution halted.
2:Torture Test ran 3 minutes 48 seconds - 0 errors, 0 warnings.
2:Execution halted.
1:3 minutes 48 seconds
Vcore is already at 1.4 and the next one up
