Opening hotmail with Firefox
Caroline
You know how you go on msn and you click on inbox and it goes to your email. How do you set it to firefox? Can you even do it? Because IE sucks and stuff....:S If anyone knows please help me. Thanks
assuming you are using windows live messenger. Download something called stuffplug. If you are using the older version of msn then try the same program. Once downloaded, open msn, go to options and check use default browser to open all mail. Problem solved
Thank you ^_^
Glad to see you got it sorted BabyDollQt. If you found glocktodahead's assistance helpful you may wish to award him some reps. You can do this by going to the helpful post he made and look for the cross/tick button below his avatar (below where it says his location etc, on the lh side). Simply click on it and add the reason why he was helpful, and then confirm. Nice work glock for helping a damsel in distress :)
will dooooo
