Scoob
Active member
Hi all,
Odd question maybe, but after a few years using water cooling in my gaming PC, I'm building up a little store of old GPU water blocks.
Basically I started off with two miss-matched GTX 570's, one of the original long PCB editions (same as 580) plus one of the newer, short "HD" editions. I fitted different water blocks to each. After the original 570 developed a fault, I replaced it with a second GTX 570 HD, so had to buy another water block for that.
Eventually, these GPU's were replaced. I popped the Air Coolers back on these and used them to upgrade a couple of older PC's - the 570's were a bit overkill, considering what the PC's are used for, however they were far less power hungry than the GPU's already there, so still a good choice.
This left me with three perfectly good EK GPU water blocks. Two suitable for the smaller GTX 570 HD, and one suitable for the original large PCB GTX 570, which also fits the GTX 580.
I got myself a pair of GTX 680's at a good deal - ironically only a month or so before the 780 was announced, ah well! Put a pair of beautiful Alphacool Nexxos GPU Blocks on these - copper and brushed steel, they look lovely - and have run these for a while now.
So, I've had the GPU upgrade itch for a while now, a single GTX 980Ti should, in theory, out perform my pair of 680's even if said 680's are scaling perfectly. I'd also get a huge benefit from the 6gb VRAM in certain titles.
I'll remove the water blocks off the two 680's, pop air coolers back on them and re-purpose them elsewhere. However, this will leave me with two more pristine GPU water blocks that only fit what is rapidly becoming obsolete (from a high-end gamer perspective) hardware.
So, my question is, what should I do with these old GPU blocks? I don't think there's a market for them - I found that out when the GTX 570 blocks originally became spare, no one appeared to want them. Can these be recycled some how? Is there any value in them? These are quite sizeable chunks of copper after all.
If anyone did want any of these blocks - only the older 570 one are available currently until I upgrade - I'd happily sell them, likely just for P&P + a little beer money so to speak, as I'd be happy just to see them used again.
What do people think, what are my options? To be fair, I'd likely have updated the 680's to 980Ti's by now if it wasn't for the extra effort required when upgrading a water cooled system. Plus, sensible thinking suggests I wait for Pascal, considering the premium price NV high-end always demands. Wouldn't want a new GPU to feel old only a couple of months into ownership
Any advice or general comments welcome, I've been pondering this for a while now & don't want to add to my collection of old water blocks!
Scoob.
Scoob.
