as i have written, i have found a funny problem with my motherboard.
im in middle of an hardware upgrade, from this spec:
Asus Crosshair formula ii motherboard
cpu: 64 2x 5000+ 2.6GHz oc to 2.99GHz running stable with out any problems!
GPU: MSI Nvidia GTX 570 twin frozr iii pe oc down clocked with MSI afterburner to
core clock: 405, shader clock: 810, memory clock: 950 (i will tell u later why)
ram: GEIL 2*2GB DDR2 ram
PSU: power viking 1000W power surply
thermaltake xaser VI with water cooling to CPU
2 HDD, one 500 GB and one 1 TB. sata 2
and im planing to build this system:
ASUS P8P67 Deluxe
cpu: Core i7 I7-2600K 8 MB
ram: Crosshair vengeance 4*4GB DDR3 duo port 1600MHz
same GPU, PSU, rig, watercooling to CPU, aswell as my HDD, will get an SSD later, as i can effort one.
my problem is atm. that after i have replaced my old asus en9500gt 1GB GPU, to my gtx 570, i have had problem running my GPU at normal stock. because my pc simply shuts down wen stressed. like beanchmark or furmark aswell as heavy games. but i later found, that if i down clocked it to as low as possible, i could run my beanch marks and games again. but still had problem that over a LAN party, over a weekend, that i had to face up to 5 shutdowns, while gaming.
i have asked some guys who is being learn in the way of making games here in denmark, where im from. that i could be because my motherboard is so poorly made, that it can shot-circuiting, because of static voltage, made from my GPU. aswell that it could be my HDD.
i have tested my PSU, if it had a problem giving power enough, to my system, so i placed it in another bigger pc, than mine, and used my gtx 570 aswell, to run on another system. and it worked just perfect. so im down to only my motherboard, and HDD.
i hope u peeps, can help me out, telling me, what causes the problem, i have done what i can, to find a reason for my unwanted shutdowns.
ps. TinytomLogan (i hope i got ur name right) great show!
aswell as rest of the team!
still just a new viewer, but i love ur show!
keep up the good work!
pss. sry my spelling. i know i have some gramma problems. but just ask, if there is somthing that u don't get. thanks.
ASUS P8P67 Deluxe
