Hello,
I have a P8Z77-i Deluxe with a 3570k, not overclocked all as standard out of the box, 16 Gb of ram not overclocked and a 7950. all running via a AXI 760 psu.
I have a random problem where i have been playing for days with no issues then i get a no signal on my monitor, i then restart the system to the same issue, i also then power off for 10 mins and still get the same.
then it wont do it for days and then does it on start up and takes 20 or so tries to get it started.
nothing is over heating nothing is over clocked, very random problem.
people have said it may be a dodgy PCIE connector on the motherboard yet if i wiggle the GPU nothing happens.
all cables are plugged it well and i have tried both cables, and different cables to rule that out.
Am i looking at a dieing motherboard ? GPU or monitor ? nothing what so ever shows up in the event viewer
