OmegaStalker New member Mar 19, 2009 #21 Moogle those fans your buying ARE 10mm deep like gav said... are you sure thats thin enough?
M moogle New member Mar 19, 2009 #22 name='OmegaStalker' said: Moogle those fans your buying ARE 10mm deep like gav said... are you sure thats thin enough? Click to expand... I'm sure. I've measured my own OCZ broken ones and they were 10mm deep. I'll go re-measure them to be sure
M moogle New member Mar 19, 2009 #23 Calipers say 10.82mm thick They're the same size so they'll fit :wavey:
G GavX New member Mar 20, 2009 #24 hmm, might buy a few of these later this week if I do my "PC parts" shopping Thanks!
Lynx New member Mar 20, 2009 #25 here mate http://www.performance-pcs.com/cata...=22166&zenid=cb4fe48a6f7944492a2e259b93914b52 40x10 red led
M moogle New member Mar 20, 2009 #26 name='Lynx' said: 40x10 red led Click to expand... Close but no cookie The fan sizes are 60mm. 40mm ones are for the old style corsair cooler, and it seems they've learned by making their new one 60mm fans.
Lynx New member Mar 20, 2009 #27 they havnt learned, just that they need bigger ones for 6 lanes.. 5 mins ill find some 60 ones hhaa
M moogle New member Mar 20, 2009 #28 name='Lynx' said: they havnt learned, just that they need bigger ones for 6 lanes.. 5 mins ill find some 60 ones hhaa Click to expand... One thing that could be done is you could unsolder the teeny weeny led's off and put different coloured ones on. But these are the miniscule led's I have no idea how anyone would be able to do that
Lynx New member Mar 20, 2009 #29 http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=51&products_id=21579 closest i could get you could always just get this: http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=51&products_id=23616 or something similar and paint em wif red uv paint..
G GavX New member Mar 21, 2009 #30 Sadly thats a US shop, I want them to arrive this year I might just get those 60mm from specialtech, not too pricey and I am probably going to go overkill on the red soon anyway! UV paint is a nice idea but a no-no, no UVs in my PC, the ammount of time I game on it I will probably get sunburn... (kidding!)
