OC3D Review Gigabyte GTX560 Ti SOC
good card but its out of market when you can have 6950 cheaper and unlock to 6970 and with more v ram and faster
The 560 Ti, will the 6950 unless you are running massive resolutions. Remember unlocking to a 6970 will void your warranty and I would not recommend doing it, because there is a reason it is a 6950 and not a 6970. However you can overclock the 6950 manually, which is imho much better than unlocking it.
i doubt it will void your warranty when you have dual bios switch . it is there for a reason , also there nothing stated on warranty that you cant unlock it as i am aware.
point is 560 soc is to expensive.
I have seen a couple of people on other forums who have bricked their 6950s after flashing the BIOS to a 6970, but apparently it was only after they did that and tried overclocking them further. I don't know if it would happen if you just flashed the BIOS and didn't OC further but i'd say just play it safe and get a 560 which has loads of overclock headroom anyway.
I dont think the 560 SOC is too expensive. It is only 20 dollars more than reference. Your getting near gtx 570 performance (speculating) for a hundred bones cheaper. A couple of these in SLI would be epic.
about 90%+ of the 6950's can be unlocked with no problems ,,,infact its most prob more than that since they are the same PCB just 6970's are higher up on the binning process but with a aftermarket cooler I dont think you would run into any problems, but sayin that its best just buy the card you want than to buy the one lower and hope you can flash it problem free imo
Dont take this the wrong way but like to see what evidence you have to support this claim.
With good reason.
I'd only do it with a card I didn't pay for and planned to bench the crap out of it - which appears to be when they crap the bed.
My own cash ? Or someone who wants advice ? Get a 6970 or 560.
Im all confused whether or not to by 2 gtx 570 gainward glh or 2 of theses
570's have more GDDR5 memory. That helps though 1 580 now or 2 if you can will help alot. going by this vid 480 has 1.5GB GDDR5 like the 580 and produces a significantly better result at crunch time to the 570. What resolution will you run them? this vid is 1920x1080 and there isn't alot of games demanding like metro 2033 i think so it's a future proof need too
http://www.youtube.com/watch?v=0pZB4FMp-2w
Again not meaning say that your intentions aren't well placed but this statics give you no indication to actual failures merely what cards could not be unlocked. This doesn't give indication that cards after this was done broke at a later date.
scroll down to "Discuss this article in our forums" on that link,,, over 3 months and 79 pages of people talking about their flashed 6950s
Actually think what your finding what happens on this vid is that physx is turned on so the extra gddr5 gives it an edge but i will be using a dedicated physx card in my pc thats not really to much to worry about.
