OC3D Review: EK FC8800 GTS waterblock
Nice job there PVs. I like the new flow test!
Seeing the 8800 naked i cant help but think 'wow lots of space around the GPU... bet you could get a phase mounted on there well' :p.
Thanks Ham, I appreciate the feedback and yeah the flow test is ghetto but functional. As far as phase is concerned there is quite a substantial amount of room. I'll hopefully be crossing that bridge in the coming months when I get a unit from Kayl :)
I know it's actually meant to be a review article PV, but that's a great installation guide you've written there!
get.php
No doubt it will help a few people.
I agree about the EK blocks being pieces of art, it's just too bad they are mounted where they can't be seen!
@PV: Since the EK fullcover block has a much bigger 'footprint' than the MCW60, did you find it any more difficult to get a good flat mount over the core and all the RAM?
Great review, the results surprised me to say the least. I was always under the impression that full cover blocks underperformed GPU only blocks. The forum link at the end of the article doesn't appear to work.
name='Doddsy' said:
That block is just beautiful.
Yeah she's a beaut alright!
get.php
Hi mate, and thanks! The EK was easy to get a good mount the first time around once you had the screw holes lined up.
Thank you! Yes I must admit at feeling the same as I was always under that impression too. But that being said, I felt that the testing portion of the review was enough to provide conclusive and verifiable results. Of course there is always the element of user error; i.e TIM application, getting a consistant block mount and temp measurement etc (I was only able to take water temps at the top of my 'T', where the res would have been preferred). Regardless, the temps and performance that I saw during the review have been posted as they were.
name='Kempez' said:
The EK blocks are easy to get a good mount - mine worked 1st time just tighten all the screws good :)
Agreed :)
I am just observing here, but it would appear that there are some slightly unexpected results. What I am referring to is that I would assume that if the GPU temperature were higher on the Swiftech, and it doesn't have the heat dump of the ram the water temperature would have a lower delta with ambient but it is in fact higher. The only explanation I can think of is that some of the heat on the EK block is being dumped into the ram and mosfets, but that is hard to believe. Please don't take this as a criticism I am mainly trying to understand and figure out which is best considering I might get an 8800 at some point.
Not at all mate, I value the constructive criticism and I can understand your question and see why you've brought it up. I'm currently running the MCW60 bench again to compare. Thanks for bringing it up.
It wasn't criticism, sorry to cause you work. :( Thanks for looking into it.
Edit: I was just thinking that since the EK has a slightly lower flow it should need to add more energy to a unit volume of water since it spends more time in the block. This probably isn't significant though.
No it's no problem mate, I'm on a public holiday and the missus and kids are out for the day visiting friends. I'll get the results collated and up in a few.
Now to make it worse you tell me you are working on a public holiday, thanks doubly then mate. I was just reading about the coolant used and noticed that it said you used 10% Prestone coolant concentrate, is this antifreeze? If so maybe that contributed to it since it has a high viscosity maybe they wavy design of the Ek is more effective opposed to the smaller "pins".
Yeah the coolant used is Prestone with anti-freeze. It could have an adverse effect on the performance, but at that ratio I wouldn't think so.
Honestly mate, it's not a problem. In between I've been decking out a new case anyway :)
I am mostly just kidding.
That is true it is probably insignificant at that concentration.
