bertdasquirt
Code:
Que?
Que?
Hey everyone, I see there are actually two bundles for the I3 540 on aria:
The reviewed one:
• Intel® Core™ i3-540 Overclocked @ 4.20GHz - Dual Core CPU
• 4GB Mushkin Silverline 1333MHz 9-9-9-24
• MSI H55M-ED55 Micro-ATX Motherboard
• Coolermaster Hyper TX3 CPU Cooler
• Arctic Silver 5 Thermal Compound
• Pre-Assembled & Tested
• 1 Years Warranty
• No Operating System
And this one:
• Intel® Core™ i3-540 Overclocked @ 4.30GHz - Dual Core CPU
• Mushkin 4GB (2x2GB) DDR3 1600MHz 8-8-8-24 Blackline - 996744
• Gigabyte GA-H55M-USB3 Intel H55 DDR3 Motherboard
• Gelid Tranquillo CPU Cooler
• 1 Years Warranty
First one is £220 and second one is £280, never heard of a gelid cooler though any comments?. And just out of interest is the extra £50 worth paying?
Just out of curiosity, what software comes with an Aria Rig by default?
Hi Zeals,
We don't supply any software per say. We do of course supply everything that comes with the motherboard i.e. Software CD and anything extra that the motherboard vendor suppied with the motherboard. We also supply the extra socket mounting that comes with each CPU cooler incase you wish to upgrade and use the same cooler on a different platform.
Hope that helps![]()
EDIT: Just realised, you are on about our bundles right? lol![]()
I'd also rather use new parts with new psu not risking the fact that the psu is dell and is over 6 years old.
Then throw in a gtx 570 for a laugh because that will only cost another £100
that i3 on the review has the same vantage score as my q8200@3.22ghz. Based on that do you thing it can handle well a card like the hd5970 (I'm waiting for the 6990 to buy it)? Or should I upgrade my cpu before thinking in upgrading my 4850? Putting in other terms: budget cpu = budget videocard?
No it absolutely can't handle something like the 5970 you would be throwing your money away.
I used to own Crossfire Radeon 5770. In a review on this site with an I7 920 they knocked out nearly 18000 3d marks. In my system (Phenom 2 940 @ 3.4ghz) they knocked out 14500.
Your CPU will bottleneck anything over a 460 1gb IMO. I certainly wouldn't spend the money on a top level card and then put it in there.
BTW thanks for posting that though. Maybe now these people who keep wanting to buy X4 AMD chips can finally understand what I am saying. IE - They are no better than the 45nm quads and cost more. The I3 is where it's at now.
Alien thats almost all B******S.
Your scores were lower because it was AMD.
You will loose a bit where its a lower chip but its not huge. Look at the comparisons in the review against a 4ghz 950... slim to nothing in it.
BUT if you have that sort of money for a GPU then you may want to think about spreading the load a little more.
