OC3D Review: 8800GTS shootout - XFX 8800GTS "XXX" vs Gainward 8800GTS "Golden Sample"
name='TJS' said:
Good review, Kemp:worship:
As markkleb asked which is 'better', I think a review between the 640 and 320mb versions should be on the shortlist. I personally think the 320mb version should be pretty good even with the memory cut in half, especially if you can cut off roughly $75 (which equates to a excellent HSF or almost another GB or RAM).
I'm in line behind Frag and Herr Smith, would like to know how to overclock all aspects of the 8800GTS. I've taken mine to 600/1010 with no problems, currently run it at 600/924 (stock is 513/792, do a little math, wanted the core at 600 so 924 is where the memory should be). I've been using Riva Tuner since the ol' Coolbits is gone (couldn't figure out that regedit download from Tox), only see the core and mem sliders, where is the stream slider (or some other way we can OC it).
TJS
i use ATitool for my oc'ing and you can have it load the oc on startup and it tells the temp... i have mine running at 640/1000
havnt seen the temp go above 70*c yet cuz i got some insain air fed to my card at all times... two 80mm fans and a 120mm all blowing on it
Great review Kemp.
Somewhere along the line I was wishing u`d take a screw-driver to those coolers, the pcbs look almost identical asif these guyz are working extremely close together. Like in the same building :p
I see many are already posing whether it`s better value to get a base card and do all the clocking uself. Meh.
name='Rastalovich' said:
Great review Kemp.
They're all the same as the reference boards i expect.
As for the clocking we can oc the core but not the stream processors:(
Aye they're all reference boards basically so the coolers the same as the reference. I could have taken em apart but not sure how much use it would have been.
I took the 8800GTX apart in that review.
If your particularly interested I could take apart another GTS and post some pics?
And ye you can OC the core clocks/memory clocks but I haven't found a way of doing the stream processors yet
Is the stream process likely to involve some kind of firm upgrade that some guy is probably working on in his pc room as we speak ? lol Now these are out I guess theres a further reference for him to work off.
If I`m the only one looking for hardcore up-cooler shots, I wouldn`t bother, if I do some searching there bound to be something out there ;)
