OC3D COD4 Server Live
name='marcus000' said:
@ Default - I was on the same server as you the other day and at first I suspected something but I specatated for a while and you looked legit.. not sure who has banned you though :)
Cheers mate. Wonder why they don't vote you off for your imba sniping, if I recall it right :D
Ok so got RCON to work (I think).. Not the fancy one just the in game one.
Thing is when I try testing the '/rcon say' command and ask someone to acknowledge that they have seen it, nobody bothers.. Doesn't help much.
Could try an older version I guess.
Have you managed to successfully get rcon working through the console?
/rcon login password
Confirm you are using the above to login through the console replacing password.
Yeah man... Got it working.. It doesn't say or do anything but then the status command works and stuff like that.
Make sure you put the console to "big" by holding shift and tilde. After logging in you can put /rcon status and get a list of all the players on the server.
Worked fine for me this afternoon =)
Ahhh ok then :)
I shall try tomorrow ;)
Please note: some chimp has got it into his head that it would be funny to login under the same name as me and then use aimbot.. Nepas has a rather non-amusing screenshot to follow!!
Nepas says:
errrr u still on?
Marcus says:
no but im still logged into admin, why?
See picture below when Nepas posts it!
Well that's annoying, so the copier is the one without clan tags?
EDIT: Never mind, I read the mombot output wrong. Well that's a problem, if I notice it next time i'll be sure to ban the guy, but other than that not much to do except let everyone know :(
Yes this has been an issue for a while, enabling PB solves it. Without that though not much can be done. Have had it happen a good few times and seen it happen to others.
