O.C a Old school amd64 3200+ need some recommended cooling solutions
fadz23q
just curious to what aftermarket CPU cooler i should get for these old 939 sockets,its one of my 5 old PC's iv got running...so i thought i might do abit of O.C
im running a a8v deluxe at 2.2ghz stock, and at Most have only got it upto 2.5 ghz, ran a prime95 stress test, it lasted 45 minutes before i got my first error, anyways what CPU cooling should i buy for it,something that can drop the temps pretti well,would be great, cheers.
p.s if anyone has one of these old mobo's and has had succes O.C with them, it would be great if you could share your Bios settings with me.
If you can find one i suggest getting a Sythe Ninja or Thermaltake Tower112. I had my 3000+ up to 2.75 semi stable and 2.61 stable with a RAM divider on my SLI-DR. I was also running 1.55v on the core.
My 3000+ was cooled by the Silent Tower and it worked wonders. My X2 is also being cooled by it and the Copper Tower112 is the all copper version. Tis a beast.
