NZXT Phantom Blue LED Fans
Senator
Just started building my first rig, bought myself the NZXT Phantom like everyone else, 4 Fans are included, one being LED.
FRONT, 1 X 140mm
REAR, 1 X 120mm (included)
SIDE, 2 x 120mm, 1 x 200/230 (2 x 120mm included)
TOP, 2 X 200mm (1 x LED 200mm included)
Basically im not that interested with adding extra fans, perhaps one to take full advantage of the 5 fan control switch, but my main question would be are there any blue/red LED fans that fit or come highly recommended, i wish to replace the current fans with LED fans.
Coolermaster Sickleflow fans are awesome for shifting air and the LED's are bright and have a nice effect on the translucent black fins however they are quite loud on full wack - If you intend to buy these and noise is an issue, they still shift a decent amount of air on low setting (I had 2 installed at one point)
