NZXT Phantom 820 Matte Black
kill_mark
Hi all,
Recently upgraded my case, and I'm loving it. Coming from Coolermaster HAF 932 to NZXT Phantom is a huge difference. I removed to top 200mm fan and filters to change it to Corsair H100. Planning on upgrading to H100i when it becomes available in our country. Looking for a blue paint for my RAM's heatspreader.
Specifications:
Case - NZXT Phantom 820 (Matte Black)
Motherboard - Asus P8Z77-V Deluxe Bios: 1709
CPU - Intel i7-3770K Stock Clocks
Memory - 8GB G Skill Trident X 2400MHz
Cooler - Corsair H100
SSD - 256GB OCZ Vertex 4 FW:1.05
HDD - 750GB WDC Caviar Green
GPU - 2GB Palit GTX 680 Jetstream
PSU - Seasonic x760
Fans - 2x Corsair SP120 PE with stock fans on H100 push/pull configuration
Peripherals:
Monitor - Samsung P2250
LCD TV - LG 32LK430
Keyboard - Razer Blackwidow Ultimate Mac Edition
Mouse - Razer Mamba
OS:
Mac OSX Mountain Lion 10.8.2
Windows 8 Pro 64-bit
Tidy up my cables and looking for a Switch 810 Matte Black side panel to replace my side panel as I like big window. Using an external dvd-writer for DVD's. Dual boot OS, planning on getting 256GB Samsung 840 Pro to be used on w8pro and Vertex 4 on ML 10.8.2. Planning on getting 2 AF140 for rear fan and bottom fan. Will update if there are changes on my build.
Looks awesome!
Looking into computerparts to buy a new computer as soon as I get home from England, although, from what I can find on forums, the H100i doesn´t fit in the Phantom 820. How did you get it to fit?
The only thing Radiator possibilities says is 3x120mm at top. But it dosent say how far between the fans, as from what I heard, the H100i needs 20mm between the fans, while the Phantom 820 only got 15mm. But thanks for your answer.
That would be the H110, which uses 140mm fans.
Corsair said:
Hydro Series H100i requires a case with dual 120mm fan mounts with 15mm spacing for a 240mm radiator
http://www.corsair.com/us/hydro-series-h100i-extreme-performance-liquid-cpu-cooler.html
Bottom of the page :)
