NZXT Phantom 410 White or CM Stryker?
XDroidie626
Hey guys!
so i have been looking at CM Styker a lot as my new case, but i looked on maximum PC and they said NZXT for the cream of the crop stuff, my budget is around £100 to streth to £120, need a good size case, ino the 410 isnt E-ATX but i aint water cooling.
The case has to be white and maybe top mounting fans :)
Please post your comments below
Thanks in advance!!!
I personally think in a case the size of the striker, unless you're watercooler and/or running multiple graphics cards in SLI/Crossfire it's going to look a little stupid.
I'd probably say the Phantom because of this.
If i were you I would get the NZXT switch 810 as it looks are great and cooling is good. Also there are many radiator mounting options which is good for the future.
I personally would wait and buy a really high quality case, like a Lian Li or a Silverstone these are cases you'll use still in 10 years.
I just got a switch 810 in white, love it :) I recommend one of those. loads of room, well built, lots of options for air/water, and it fits loads of radiators :D
well i was looking at the Corsair 600t, im unsure on this case, i like the look of the 810 over the Stryker atm, but ill have to see what linus videos say on it xD
Tom did an awesome long review on it, it's one of the main reasons i bought the case (thanks tom)
