NZXT Kraken X62
billyboy82
I must say this cooler looks amazing!the pump design,the RGB,the radiator,the hoses quality,all looking great,but does it perform the same way next to,another flagship,the h115i?I was planning to get for my new gaming rig the h115i but after watching TTLs video on the x62 i just went crazy with the aesthetics and all i want now is to cheat on corsair with this NZXT beauty :) how about performance though??!! Do you think x62 will perform even or better than an h115i?is it possible to mount different fans (noctua for example) for better cooling and less noise?
Review:
You say how does it perform.... Its all in the video.
It's all in Toms review of it, if you have watched it. And yes, you can change the fans for the ones you'd like. As the included fans aren't exactly soldered to the radiator ^_^
Thanks guys,i hadn't realized there was a full review!i've only seen the rushkit video.very nice review and yes it's all there!!cheers!
