The_Governour
I want to make my next build a fully water cooled H440 with the following specs:
MOBO: Asus Hero
* RS 360 rad at the top with push
* XTX 360 rad at the front with push/pull
Now, I would like to use the XSPC Photon 170 Tube Reservoir with a EK LAING D5 pump but WHERE could I place it? I am trying to find more info on it but it seems that there is no 2 x 360 rad build out there that shows where the pump and rad would go.
If I could then I would like to mount the XSPC Photon 170 Tube Reservoir where the exaust 140 fan is placed but then would there be enough space below to place the pump? I would think for a future water cooled GPU then the pump below the res would not fit.
I am very confused over this matter - could some one help me out?
All I have seen so far is this video where they have a 240 rad I think at the top and a 360 at the front but ONLY in push..
And they have placed the pump at the front of the 360 front rad but it is not in push/pull like I want it....
Need help........ Tom... maybe could you do a video about a full water cooled set up with 2 x 360 rads with push pull - as its one of the best cases you have rated so far at this price range???
MOBO: Asus Hero
