Nvidia GTX Titan X 4K Gsync Review
Sometimes the minimums stay the same and sometimes they scale.
With SLI if you are going to use it, always go for the fastest cards you can get your hands on.
Using GTX 960s in SLI is bad I know as I own a couple. The minimums with one is often bad and sometimes it does not improve with two.
This. Sometimes you're going to need to fall back on one card so don't go SLI on a hope and a prayer.
Only do it to achieve higher frame rates, never to depend upon it.
Last few SLI pairing for me have been high end.
I depend on it for 4k and it can be problematic, especially in poor UBI games.
"...but as a site that prides itself on looking at things with the eye of the common user it's nice that the more affordable option is around to begin with so you can choose whether to spend the money on a Titan X, rather than spending the money on the best GPU available only to discover you could have spent half as much for almost the same performance level a month later."
How naive these words seem now :D
