So. U tell me that GT 630 bottlenecks with 7750, while 4670 does not?
And plz dont propose me new stuff to buy, theres no such option for my friend.
What free fix? I need a specific answer to tell to my friend, because he thinks he got a better card than his previous one(4670).
I repeat the question; GT 630 bottlenecks with 7750, while 4670 does not?
Its not necessary to explain it multiple times, just one is enough, but has to be specific.
What do u mean "those gpu's"? u mean the new ones? GT 630 is one of them, 4670 is not?
If yes, then it makes some sense. And explains why that site gives +200 points to 630.
What do u mean "those cards are nearly on an even level"?
Which cards?
How is possible gt 630 and 4670 be even when WEI gives 6.6 and 6.8 ?
Plus that gt 630 gives less fps in "FlatOut 2-Ultimate Carnage".
One explanation could be that gt 630 receives bottleneck from 7750, while 4670 not.
There is a confusion. Is 630 weaker, equal or faster than 4670 ?
If the above explanation is right, then 630 is faster.
first of all, don't you ever quote WEI again, that stuff doesn't mean anything. base your stuff on real benchmarks.
there is never a clear winner, some games are optimized for AMD, some are optimized for nvidida.
the reason why the 630 does better than the 4670 in FlatOut2 is that FO2 probably doesnt utilize the CPU much, i.e. the bottleneck is smaller.
The 630 is overall a better card, it just cant do better because games don't just use the GPU. some are more CPU dependent and therefore need a better CPU to run properly.
With even i meant that the performance difference isn't that big between those two cards. Therefore optimization can easily make the difference.
My friend...
I said that 4670 gives more fps in FO2, not the 630. And thats weird. Because supposed that 630 is better than the old 4670.
If u dont like wei, then try 3dmark06, I m sure u ll get the same result.
Especially in cpu's and cards, when wei gives better score in a devive, means that device is better. Thats what I think, but maybe u know better.
What do u mean "optimization"? Optimize how?
Since when games dont use the gpu? Is this a new evolution?
Suppose that the better card, the faster u ll run the game. Otherwise why should we buy a faster/expensive card![]()
My friend...
wow can't believe how long this has been going on for.
ok basically the 4670 was(at its release) a mid range gaming card so its architecture is designed to to process a fair amount of textures and pixels.
any Nvidia card with a 30 or 40 prefix is not designed for gaming. these cards are basically designed for video playback on CPU's which only have low end integrated graphics chips
so for current games to run at any kind of decent settings you would need at least a x60 series from Nvidia or a x6xx/x7xx series card from AMD.
the first number is the series so higher series cards are more efficient and come with new technology but bigger price tags. the second set of numbers tells you how high in the series that card is e.g: a gt 670 is better than a 660ti which is better than a 660 and so on and the top (not including specials such as the titan) usually is the 90 series from Nvidia or 900 series from AMD
so what your friend has bought is basically a video rendering card that could be used for gaming instead of a gaming card that can do video rendering.
just remember that you get what you pay for, and buy cheap buy twice.
aye i agree with you,
just trying to make some sense to this guy.
his card has 96 cores and the 4670 has 320 stream processors
I personally think that the 4670 will perform better in gaming than the 630 despite the age.
i think it would be like comparing an i5 750 against an AMD A4 3300.
that old i5 is still better for gaming even thought the A4 has newer tech
but im going off topic now.
