T Toxcity New member Apr 4, 2007 #1 Hello peeps! Just got my new rig, and well one little question about an option I found in the bios. NVIDIA GPU EX? Firstly, what is it? Secondly, Can I support it..? (running on 97.92 for 8800) Thanks!
D deathwish New member Apr 4, 2007 #2 yes turn it on its optimistions for the card you have to have direct x 9 or higher to use it tho
T Toxcity New member Apr 4, 2007 #4 name='limqareb' said: where is this found ? Click to expand... Found in the bios of nforce chipsets. I have an 8800 so it will be going on! Thanks deathwish!
T Toxcity New member Apr 4, 2007 #7 Okay guys... It does make a very little amount of difference. I run 3D mark06 all stock with EX off. and got, 8454 Ran all stock with EX on and got, 8504!
T Toxcity New member Apr 4, 2007 #9 name='chudley' said: Glad your kit turned up, see you have wasted no time lol Click to expand... No time to waste! Straight to the benching!
