Nubwo no-3000 or letton G3 Headset? HELP
umarsbid
Hi today I show the Nubwo no-3000 or letton G3 Headset but i don't know which one to get any idea were which headsets is the better one to buy. Can any one tell me what experience with these two. Thanking You
You don't want a headset. You want proper low impedance headphones and a modmic by Antlion.
You shouldn't give advice.. and again living up to your name.
OP can we have more specific details on budget and usage? Gaming, Music, etc? Knowing your location and what is available to you helps us help you as well.
That's rich...
He gave the exact advice most people here would give. Ditch the headset, get decent cans and a proper mic. The only thing I'd question is the impedance part of it.
Solid advice tbh.
He is right though if there isn't a budget.
Although the antlion mics are awful.
-edit- To answer OP's question, neither are really worth it. Look at the Gamecom 780s if you've got a tight budget. Anything less than £30 and you might as well get some decent buudget headphones and a £5 mic.
I use Logitech G35's for years now and have been solid! :) ... I broke my first pair by actually blowing the speaker of it lol. Whenever a big bass were coming from a song, it would give this cracking noise from the speaker.
Other than that, they have been solid... used to be quite into the whole headset market etc, but more towards gaming and budget oriented. This sounds more to the professional grade level.
Both headsets the OP mentions are super cheap ones. You can't compare them with the G35 or something along those lines...
The least expensive I could possibly say is good is the Philips SHG7980 headset or you can buy Sennheiser's HD 201 and a 5 dollar microphone...
That's rich...
Solid advice tbh.
There's a difference between good and bad advice, he was on the right track but it just leads to more questions than answers. Like you said, the impedance part of it. Low impedance headphones.. wth does that mean? That doesn't help at all nor does it equate quality. A product recommendation would be more useful. It's not solid advice tbh.
I own a modmic, love it. It's crystal clear to people I play with. Wouldn't recommend it on a tight budget as it's not a must have. The popular Zalman one would do just fine.
OP, if you are still looking for a headset or headphone+mic(recommended) then what is the intended usage and budget?
